03-14-2014 09:58 AM
Good Morning,
I have a rules-based load-balanced queue (entitled 'My Work') that I am trying to report on . I want to count the number of documents that are placed in that queue each day, but have it broken down by the load-balanced user.
We have an assignment queue, that is a holding tank and users go into that assignment queue and assign the documents to the 'My Work' load-balanced queue. The user that is doing the assigning is not necessarily the assigned user in the next queue, in which case hsi.wflog is not helping me.
I've done some digging through the tables, but am not finding anything that is very helpful. Any suggestions as to which tables I should be looking into would be greatly appreciated.
Thanks!
Sarah
03-14-2014 11:10 AM
You're looking at documents assigned in the past, not documents assigned right now? By default load balance assignments are not logged - you can only see them in real-time. In the load balance settings there is an option to store the assignment in a keyword. If you need to do reporting on it, you'll probably need to use this option and then report on the keyword value.
03-14-2014 01:02 PM
Yes, they are in the past.
The problem with using the keyword, is that it changes later in the workflow..
03-14-2014 01:42 PM
HI Sarah,
If in the load balanced queue you use a "Keyword to Hold Assignee", you can then join on transactionxlog and extrainfo1= {Keytypenum} and action=1035 (Create keyword). At that point the logdate would have the date it entered the workflow queue.
Another way you could approach this is if the assigned users are the ones who move the document out of the queue, then you could from wflog use exitusernum={assigned user} and the entrytime and exittime would reflect queue time.
Hope that helps.
Daniel
03-15-2014 12:51 PM
Using the transaction log can work, but I usually consider it a last resort.
Sarah, can you use a specific keyword JUST for this purpose? Then it won't change later. Probably make it hidden/read-only so it can't be changed by any other means.
