06-19-2024 01:34 PM
User does not have rights to create document or when the user is trying to add read-only and hidden keywords without 'Access Restricted Keywords' privilege.
06-20-2024 06:49 AM
Figure out the issue, with help from this thread, REST API Request having issue updating keywords. (hyland.com)
I'm caching some of the results on API calls that are less subject to change and presumably have a long TTL. It looks like the caching of one of those calls `GET /document-types/{documentTypeId}/default-keywords`, was resulting in the GUID I passed up in the `POST /documents ` to be considered invalid on the OnBase side. Even though the default keywords didn't change, it sounds like the GUID associated with them is subject to change.
Once I ignored the cache, and always fetched the default-keywords (in the document create chain), all subsequent calls to POST /documents succeed without issue.
06-19-2024 02:19 PM
Hi
I'm guessing that this will be easier by engaging API support to review you code as without it, troubleshooting might be difficult.
However, here are some questions ...
- Could you provide more context on what you mean by the first attempt works and subsequent attempts fail?
- Does this mean that you create a session and then iterate through multiple document uploads?
- What type of License are you using when you create the session?
- Does it work if you open a session, upload the document and then close the session prior to uploading a new document?
Thanks.
06-20-2024 05:22 AM
Hi Adam,
Thank you for your reply.
Sure. I'm making 8 API calls to do the full document upload process and in a brand new session, they all succeed.
06-20-2024 06:46 AM
Thanks for the info
First though is related to the Cookie.Session.OnBase.Hyland cookie. You will need to maintain that cookie in your requests to the Application Server. This is how the users OnBase Core Session is maintained from one request to another.
Additionally, you'll have to maintain the Access Token you received from the Hyland Identity Service in order to make requests to the REST API endpoints. I'm assuming this is being performed correctly else all of the REST API endpoints would fail.
I had asked about closing the session prior to trying to upload a new document ...
... but in your scenario it is failing when attempting to archive the document.
This is before you would want to close the session. However, since you are going to attempt to archive multiple Documents in a single session, there is no need to close the session until you completed the work you are looking to perform.
Yes, the REST API Toolkit license is requires to support the use of the REST APIs, but you also need a Client License. Based on what you mentioned, you are using a default license which would be either a Concurrent Client or a Named User license, depending on the configuration of your user account.
I doubt this is related as you would run into other errors, but something to consider none-the-less.
For next steps, I would see what errors are logged under the ApiServer profile in Hyland Diagnostics.
Best wishes.
06-20-2024 06:49 AM
