08-14-2019 07:19 AM
Hi.
I created the system disk group and the system assigned ID 102 instead of 101. How can I solve it?
Thanks for your help.
08-14-2019 09:36 AM
Hi Diana,
Please contact your FLOS for assistance with this particular issue. There is a fix, but it involves running a SQL script in order to resolve, which your FLOS has access to.
Hope this helps,
Joel
08-14-2019 07:49 AM
Diana,
Why you want it to be 101? It is internally referred by that Number. I have 102 assigned to SYSTEM in my Dev environment also and not facing any issues as such
Kind Regards,
Ashish Srivastava
08-14-2019 08:20 AM
function (id) { $http.post('/api/comment/create', { ParentItemId: id, Body: self.commentBody }).then(function (response) { location.href = location.pathname + '#Reply_' + response.data.Id; location.reload(); }); }
In the demonstration virtual machines it is referenced to 101, also in the database; and in the documentation it mentions that the import of icons and bitmaps must be to disk group 101.
In my implementation, in the configurator, the system disk group is assigned the number 102, also in the database.
P.S.: Sorry for my bad English, it's not my native language.
08-14-2019 08:19 AM
08-14-2019 09:36 AM
Hi Diana,
Hope this helps,
Joel
