10-14-2015 11:58 AM
Happens during data source setup. Thanks in advance
Exception of type 'Hyland.Public.ServiceException' was thrown. ---> Source: Has been filtered
TargetSite: Has been filtered
Exception: Cannot perform this operation before data source 'onbase_live' is initialized.
---> The stacktrace has been removed. Please contact your administrator and provide error id: 27ed8db1-d00c-4fdb-b523-fa3a4b2ca6aa to get more information.
End of Service Exception from Server.
at Hyland.Types.Response.Validate()
at Hyland.Canvas.ReportServices.Configuration.ServiceCommandManager.ExecuteCommandsImpl(Boolean useAsyncRequest, Action continuation, Action`1 onError)
at Hyland.Canvas.ReportServices.Wizards.DataProviderCommon.SelectDataProviderDisplayColumns.OnLoadedOnce()
at Hyland.Canvas.ReportServices.Wizards.WizardPage.OnLoadedInternal(Object sender, RoutedEventArgs e)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
10-14-2015 03:15 PM
Pls disregard. A full IIS restart seemed to fix this problem.
10-30-2015 06:39 AM
02-10-2016 11:03 AM
Trevor & Jerry,
I just wanted to followup, the issue was identified and there was an SCR created to address this. If you contact your first line of support you can have your account added to the SCR #236159 so that you are notified when it has been completed.
Thank you,
Todd Bailey
04-01-2016 03:48 PM
Is this already fixed? i'm having the same error message on Reporting Dashboards Data Provider Wizard
