02-13-2017 11:24 AM
I am running into below issue. I am working on a Unity WF Script and I have added V4.0 System.Core also. I am getting below error.
The type or namespace name 'Linq' does not exist in the namespace 'System.Xml' (are you missing an a
ssembly reference?)
Any idea how can I solve this error?
Thanks for the help.
Regards
Srinivas
02-13-2017 11:36 AM
Hi Srivinas,
This is an issue in versions earlier than 16. Linq includes static references that are incompatible with the Unity script environment.
Options to fix the problem are:
1. Upgrade to v16, where Linq is supported
2. Convert to a loop or other object that doesnot use Linq
Hope that helps,
-Scott
02-14-2017 01:28 PM
If I am not mistaken, Importing assemblies was added into the OnBase Studio Script editor in Version 15. Assemblies can still be imported and assigned to a script within the older Configuration Script Editor under Config | Queries | Unity.
Please be sure that OnBase Studio is not opened when the Config Editor is used. Also, please note that importing an assembly is available in OnBase Studio in later versions, and the Config Editor is planned to be removed in OnBase 17.
In versions that do not allow assemblies to be imported, custom assemblies can be made Strongly-Typed and added to the System GAC for reference.
