yesterday
I am creating a Workflow Unity Script and using a library to extract text from PDF documents. The library has several different DLL files, and I was able to import one of the assemblies which seemed to recognize and import the dependent assemblies as well.
I need to add references to some of the other dependency assemblies, but I can't seem to find them in the Imported assemblies or the System assemblies. If I try to import the other DLLs, I get a message that "a valid assembly with the same full name was found but assembly bytes differ."
I haven't actually imported DLLs for PdfPig.Core or PdfPig.Tokens, but it seems like they exist somewhere.
12 hours ago
I figured it out. The package came with DLLs for different versions of .Net Framework. I had originally imported the PdfPig.dll for 4.6.1, and then got mixed up when trying to import one of the other DLLs and was choosing a dll file from 4.6.2 folder.
I was able to successfully import when I tried the correct dll from the 4.6.1 folder.
19 hours ago
Did you or your administrator looking around database with the name of this dll's?
12 hours ago
