08-06-2024 09:11 AM
Since my upgrade from 21.1 to 24.1 I have found that the Connection Strings defined in Studio are not working in Unity Scripts in Workflow Rules/Actions.
I am getting an exception:
"System.InvalidCastException: Unable to cast object of type 'Microsoft.Data.SqlClient.SqlConnection' to type 'System.Data.SqlClient.SqlConnection'."
The script references don't seem to allow adding of Microsoft.Data libraries. (I have System.Data, but that doesn't appear to be the type used by studio for the SQLConnection any longer.)
Any advice on getting this fixed would be great!
08-08-2024 02:30 AM
The quickest way to resolve this is likely by contacting your First Line of Support (FLOS), but there is something that might be worth checking first.
I'll briefly describe this check, then I'll give a more detailed explanation below.
Take a look at the connection string that's being used in your scripts:
Does it include an Encrypt attribute, as in the above example?
If so, then if the Encrypt attribute value is optional (as above), try changing it to false.
And if the Encrypt attribute value is mandatory, try changing it to true.
After making any changes to the connection string, restart the Application Server so OnBase picks up the changes (that should happen automatically when you save the changes in web.config).
If there is no Encrypt attribute, or there is one but its value is already true or false, or you make the change and it makes no difference, then I recommend contacting your FLOS for further troubleshooting
Detailed explanation:
If checking/modifying the connection string's Encrypt attribute as described above worked, here's the explanation:
If your OnBase database is Sql Server, OnBase communicates with it using ADO.NET. (Apart from the OnBase Thick Client, which uses a different protocol, ODBC).
The ADO.NET communication uses Microsoft's .NET libraries. Prior to OnBase 24.1 we used the System.Data.SQLClient library. But then in OnBase 24.1, following Microsoft's guidance, we changed to a more modern library, Microsoft.Data.SQLClient.
(This article explains why Microsoft recommended moving from System.Data.SQLClient to Microsoft.Data.SQLClient: https://devblogs.microsoft.com/dotnet/introducing-the-new-microsoftdatasqlclient/)
As far as the existing database functionality is concerned there's no difference: Microsoft.Data.SQLClient is backwards-compatible with System.Data.SQLClient.
However, the connection strings are not totally compatible. There's a difference in the way System.Data.SQLClient and Microsoft.Data.SQLClient treat encryption of the database connection.
Microsoft.Data.SQLClient defaults to encrypting the database connection, so if there's no Encrypt attribute in the connection string, the database connection is encrypted. Previously, with Microsoft.Data.SQLClient , the default is an unencrypted connection; to specify an encrypted connection, you have to include an explicit Encrypt=true in the connection string.
To use an encrypted connection, you need to set up the appropriate certificates: https://learn.microsoft.com/en-us/sql/database-engine/configure-windows/certificate-requirements?vie...
If you don't want, or haven't configured, SQL Server for encryption then if you're using Microsoft.Data.SQLClient you have to explicitly set Encrypt=optional in the connection string.
OnBase 24.1 internally uses Microsoft.Data.SQLClient . But it's possible there are Unity Scripts that still use the older library System.Data.SQLClient . The binaries for both are included with OnBase, but if they're both using the same connection string, you have to ensure that the values are compatible.
This means that any Encrypt attribute value must be compatible with both. Microsoft.Data.SQLClient accepts values of mandatory/optional/strict, but also accepts true as a synonym for mandatory, and false as a synonym for optional. If omitted, the default is mandatory.
System.Data.SQLClient accepts values of true/false; if omitted, the default is false.
So if you want to allow Microsoft.Data.SQLClient and System.Data.SQLClient connection to use the same connection string, you need to explicitly include an Encrypt=true or Encrypt=false attribute, depending on whether the database connection is encrypted or not.
To return to this specific situation where connections in Unity Scripts are failing. My guess is that the scripts may be using System.Data.SQLClient but the OnBase connection strings have been updated to include incompatible values (e.g. optional) for the connection string Encrypt attribute. Hence my advice to check, and for compatibility change the Encrypt values to true or false.
08-08-2024 09:27 AM
That does all make sense for the most part. We are using System.Data as the Referenced Assembly in our C# and VB scripts.
The sticking point is that Studio doesn't seem to allow adding the Microsoft.Data.SqlClient as a reference into the scripts. (no Microsoft.Data assembly is listed under System Assemblies, just items like Microsoft.Data.Tools.<stuff> )
Would Microsoft.Data base assembly have to be an Imported Assembly?
SqlConnection conn;
conn = (SqlConnection)app.Configuration.GetConnection("SQL_PSE");
I have been making do currently by changing my scripts to
String connStr = app.Configuration.GetConnection("SQL_PSE").ConnectionString;
SqlConnection conn = new SqlConnection(connStr);
08-09-2024 04:07 AM
My apologies: I don't think my answer was addressing your problem. It looks like you may have found an issue with the way OnBase Studio handles system assemblies. I don't have any specific ideas for further troubleshooting, other than to contact your FLOS for assistance.
