using System.XML.Linq in unity WF Script
Srinivas_Kaira1
I am running into below issue. I am working on a Unity WF Script and I have added V4.0 System.Core also. I am getting below error.
The type or namespace name 'Linq' does not exist in the namespace 'System.Xml' (are you missing an a
ssembly reference?)
Any idea how can I solve this error?
Thanks for the help.
Regards
Srinivas
Scott_McLean
Elite Collaborator
Elite Collaborator
Hi Srivinas,
This is an issue in versions earlier than 16. Linq includes static references that are incompatible with the Unity script environment.
Options to fix the problem are:
1. Upgrade to v16, where Linq is supported
2. Convert to a loop or other object that doesnot use Linq
Hope that helps,
-Scott
15 REPLIES 15
Alex_French
Elite Collaborator
Elite Collaborator
Have you added a using statement in addition to the Reference?
You probably just need:
using System.Linq;
Scott_McLean
Elite Collaborator
Elite Collaborator
Hi Srivinas,
Hope that helps,
-Scott
Hi Scott,
Good to hear from you.
We are on V13. Do you know if Unity Script has problems with XML.Linq also?
Srinivas
Yeah. You're not going to be able to use Linq in v13. Sadly, this means building longer routines to replace the simplified Linq ones (or of course, upgrading to v16, where this is fixed).
