How to specify NameIDPolicy-Format in SAML2 using Hyland IdP
Kiri_Yoshidaya
Hello all,
We're configuring SSO in Azure AD (SAML2) using Hyland IdP.
Configuration seems to complete properly, and the login was successful, but not in the desired state.
We're planning to log in to OnBase using email address, but now using persistent ID to log in to OnBase instead.
I believe that this is because Azure AD returns NameID in the SAML Response as persistent format, as shown below:
<NameID Format = "urn: oasis: names: tc: SAML: 2.0: nameid-format: persistent"> xxxxx </ NameID>
I contacted the Azure AD administrator and they told me that the NameID is set to user.mail, so if including the
<NameIDPolicy Format = "urn: oasis: names: tc: SAML: 2.0: nameid-format: emailAddress" /> tag in SAML Request,
AD should return email address.
Is it possible to specify NameIDPolicy in OnBase IdP settings?
If possible, how do I set it up?
Thanks in advance.
AdamShaneHyland
Employee
Employee
Hi Kiri.
You can send back the claims via SAML in any format.  From there, the OnBase IDP (OnBase 17/18) or Hyland IDP (OnBase Foundation EP1 and higher) can be configured to read the Name attribute from the Attribute Claim(s) in the SAML Response.
For Azure AD, I found this article which might be helpful ...
     https://docs.microsoft.com/en-us/azure/active-directory/develop/active-directory-saml-claims-customization
For instance, the following is a portion of a SAML Response ...
<AttributeStatement>    <Attribute Name="http://schemas.xmlsoap.org/ws/2005/05/identity/claims/name">        <AttributeValue>John Doe</AttributeValue>    </Attribute>    <Attribute Name="http://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress">        <AttributeValue>jdoe@domain.com</AttributeValue>    </Attribute>    <Attribute Name="http://schemas.microsoft.com/ws/2008/06/identity/claims/role">        <AttributeValue>Scanning Users</AttributeValue>    </Attribute></AttributeStatement>
Here you can see the reference to http://schemas.xmlsoap.org/ws/2005/05/identity/claims/name which is the reference to the users full name in the SAML Response.
The following would be the corresponding UserAttributeMappings in the idpconfig.json for the Hyland IDP ...
"UserAttributeMapping": {  "username": "http://schemas.xmlsoap.org/ws/2005/05/identity/claims/nameidentifier",  "email": "http://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress",  "realName": "http://schemas.xmlsoap.org/ws/2005/05/identity/claims/name",  "group": "http://schemas.microsoft.com/ws/2008/06/identity/claims/role"},
As long at the value is send in the SAML Response and is an Attribute, it can be mapped to OnBase.
Best wishes.
5 REPLIES 5
AdamShaneHyland
Employee
Employee
Hi Kiri.
Best wishes.
Hi Adam.
Thank you for your comment.
We already refered Microsoft documentation, and configured the UserAttributMapping properly -- as you shown -- using Hyland IdP Server configuration,  but SAML Response didn't contains any user attributes...
like below :
<Attribute
Name="http://schemas.microsoft.com/identity/claims/tenantid">
<AttributeValue>xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx</AttributeValue>
</Attribute>
<Attribute
Name="http://schemas.microsoft.com/identity/claims/objectidentifier">
<AttributeValue>yyyyyyyy-yyyy-yyyy-yyyy-yyyyyyyyyyyy</AttributeValue>
</Attribute>
<Attribute
Name="http://schemas.microsoft.com/identity/claims/identityprovider">
<AttributeValue>https://sts.windows.net/zzzzzzzzzzzzzzzzzzzzz</AttributeValue>
</Attribute>
<Attribute
Name="http://schemas.microsoft.com/claims/authnmethodsreferences">
<AttributeValue>http://schemas.microsoft.com/ws/2008/06/identity/authenticationmethod/password</AttributeValue>
<AttributeValue>http://schemas.microsoft.com/ws/2008/06/identity/authenticationmethod/windows</AttributeValue>
</Attribute>
Our SAML Request is like below:
<saml2p:AuthnRequest
xmlns:saml2p="urn:oasis:names:tc:SAML:2.0:protocol"
xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion"
ID="idxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
Version="2.0"
IssueInstant="YYYY-MM-DDThh:mm:ssZ"
Destination="https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/saml2"
ProtocolBinding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST"
AssertionConsumerServiceURL="https://HylandIdPServer/identityprovider/Saml2/Acs">
<saml2:Issuer>https://HylandIdPServer/onbase/smesaml</saml2:Issuer>
</saml2p:AuthnRequest>
Then, SAML Response that behave properly at customer's  environment like below:
<Attribute Name="http://schemas.microsoft.com/identity/claims/tenantid">
<AttributeValue>xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.microsoft.com/identity/claims/objectidentifier">
<AttributeValue>yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.microsoft.com/identity/claims/identityprovider">
<AttributeValue>https://sts.windows.net/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/
</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.microsoft.com/claims/authnmethodsreferences">
</AttributeValue>
<AttributeValue>http://schemas.microsoft.com/ws/2008/06/identity/authenticationmethod/x509
</AttributeValue>
<AttributeValue>http://schemas.microsoft.com/claims/multipleauthn
</AttributeValue>
</Attribute>
<Attribute Name="User.email">
<AttributeValue>email@customer.com
</AttributeValue>
</Attribute>
<Attribute Name="User.FirstName">
<AttributeValue>Company Abbrev.
</AttributeValue>
</Attribute>
<Attribute Name="User.Username">
<AttributeValue>99999999
</AttributeValue>
</Attribute>
<Attribute Name="memberOf">
<AttributeValue>GroupName
</AttributeValue>
</Attribute>
<Attribute Name="User.LastName">
<AttributeValue>UserName
</AttributeValue>
</Attribute>
<samlp:AuthnRequest
xmlns:samlp="urn:oasis:names:tc:SAML:2.0:protocol"
xmlns:saml="urn:oasis:names:tc:SAML:2.0:assertion"
ID="ONELOGIN_xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
Version="2.0"
Destination="https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxxxxxx/saml2"
AssertionConsumerServiceURL="https://customerwebsite/login.php?saml_acs">
<saml:Issuer>https://customerwebsite2</saml:Issuer>
<samlp:NameIDPolicy
Format="urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified"
AllowCreate="true" />
</samlp:AuthnRequest>
The only difference is if there is a NameIDPolicy specification. So I think that the best way to resolve our problem is set NameIDPolicy in Hyland IdP.
Or, there are some misconfiguration -- restriction of return value(s) for our request at AzureAD side.
How do you feel about?
Hi Kiri.
Based on the above example, you should be able to map the attributes in the SAML Response.  For instance ...
  "username": "User.Username",
  "email": "User.email",
  "realName": "",
  "group": ""
Note, I didn't see a valid mapping for the realName or group in the SAML Response.
Take care.
Hi Adam.
After careful checking our all parameters again according to your advice, and came to the conclusion that our configuration is correct.
So we confirmed to Azure AD admin again and found a misconfiguration at Azure AD.
In actual, our test user account on Azure AD was not licensed M365(Mail), so Azure AD did not return E-mail address.
Fixing AD setting, and connected successfully.
Thank you for your corporation.
Regards.
Kiri
