Finding duplicate documents and selecting their document handle
Steven_Zeltner4
I'm looking to get a list of document handles that have a duplicate.  A duplicate is defined by a 5 keyword match.  The approach I'm taking is something like:
SELECT id.itemnum,COUNT(*) As numoccurrences
FROM hsi.itemdata id
JOIN hsi.keyitem513 ki513 ON ki513.itemnum = id.itemnum
JOIN hsi.keyitem514 ki514 ON ki514.itemnum = id.itemnum
JOIN hsi.keyitem515 ki515 ON ki515.itemnum = id.itemnum
JOIN hsi.keyitem516 ki516 ON ki516.itemnum = id.itemnum
JOIN hsi.keyitem517 ki517 ON ki517.itemnum = id.itemnum
WHERE id.itemtypenum = 413
GROUP BY ki514.keyvaluebig,ki515.keyvaluesmall,ki516.keyvaluedate,ki517.keyvaluechar
--HAVING COUNT(*) > 1
That's a rough outline of a (broken) query.  I realize that this query isn't going to compile because I don't have id.itemnum in the GROUP BY clause but I stopped here to ask the Community about whether or not the approach is sound.
Is using a Group By clause wise here?  How would you find a document where 5 keywords matched?  It doesn't make sense to Group By itemnum but that is what I'm trying to get to (eventually).
I'm having some luck with this since I don't really care what doc handle is kept:
SELECT MAX(id.itemnum), COUNT(*) As numoccurrences
HAVING COUNT(*) > 1
Any other thoughts out there for a better way?  I'd imagine this will be pretty resource intensive.
Thank you.
6 REPLIES 6
Steven_Zeltner4
Thank you for the queries and the general SQL information.  Tom, thanks for the heads up on the SQL 2012 functionality for Brad's query.  Using this thread, I was able to get back the duplicates.
Thomas_Reu
Elite Collaborator
Elite Collaborator
Steven, were you able to run both queries?  We're on sqlserver 2008 R2, so I can't gather any stats.  I'd love to have empirical information on the run times on both queries against the same data set - which you may have.  Plus a count of how many records you are processing.  If the times are that much better, then maybe I need to deal with the upgrade pain and push for a DB update to 2012 sooner versus later.
