06-08-2012 10:02 AM
Where might I find documentation on how to use VBScript with an external dataset?
Also, is this only available in Core workflow?
(Version 11)
THANKS!
06-12-2012 08:40 AM
(Version 11)
THANKS!
06-12-2012 08:45 AM
The Hyland SDK is where you will find all of that information. However you need to be API Certified by Hyland to receive the SDK. If you aren't API certified, you should be able to contact you first line of support to get that information.
