05-01-2019 01:53 PM
I'm trying to do a Cascading Data Set Hyland.Unity.IExternalKeywordDataSetScript API - for the Unity/Thick Client Import. Is it possible to get the value from a parent drop down to pass to a dependent drop down? I set up the Cascading Data Set like the example in the SDK but it doesn't work - at least for me. I know there's a Cascading Data Set in Keyword Configuration but the dependent keyword is a Mixed Case Values and can't be used as a cascading data set.
Thank You,
Mike
