11-18-2021 07:19 AM
Hello
Does anyone have experience with the display of archived Documents within SAP FIORI. We are desperately trying to get the get the OnBase Web Client via SAPDOCPOP t to display OnBase Documents within SAP FIORI. As an embedded view (iFrame).
Somehow the customer on the SAP side gets an Error:
Refused to display 'https://onb-app-pre.us-XXXXX.net.com/' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
(index):2758
Everything we tried so far did not work.
Thanks for any experienced advise.
Best Regards
Dom
11-22-2021 06:10 AM
Ok. I'm aware of one other customer embedding on an IFrame. I usually only become aware when there is an issue, and that's what got their solution working. I may point you to tech support as they may have run into other scenarios.
One other configuration item to check.... On the AppNet web.config, can you please ensure that the DocPop setting embedded=true
11-22-2021 06:27 AM
Hi Ron
Many thanks for your comment. We also checked for the embedded value setting. this setting is also already set. So we still have to issue.
A support ticket is now created.
Best regards,
Reto Leuzinger
11-23-2021 05:50 AM
One last configuration item to check... On the ArchiveLink web.config, can you please make sure that the docpop url points to docpop.aspx. It should NOT point to sapdocpop.aspx.
11-18-2021 07:35 AM
Thanks Ron!!
11-30-2021 07:01 AM
Hi All
We are about testing this now ... first attempt today. Preview does not work. I think we need to understand more about this. My suggestion would be to setup a conf-call.
Br, Martin
