workview external class based on a result of unity script
Massoundi_Omar
Hi
Did someone experienced a workview external class based on a results of unity script ? i'm searching for the best practices, a quick steps guide or even a sample if possible ...
Patrick_Ramser
From Rob's sub-comment above:
"If you're trying to create an external class that uses the IWorkViewGetExternalClassDataScript interface, there's two methods of interest on that class. OnWorkViewGetExternalObject has the WorkViewGetExternalObjectEventArgs that exposes an ExternalObject that you can populate with attributes with SetAttributeValue. OnWorkViewPopulateExternalFilterResults.WorkViewPopulateExternalFilterResultsEventArgs provides access to the filter through FilterQuery; you can create several external objects through CreateExternalObject() and add them to Results."
If this isn't correct or you have anymore questions, comments, or need anything more in-depth, feel free to reach out to your first line of support, and if available, us at apisupport@onbase.com.
5 REPLIES 5
Patrick_Ramser
