01-29-2016 01:20 AM
Hi
Did someone experienced a workview external class based on a results of unity script ? i'm searching for the best practices, a quick steps guide or even a sample if possible ...
02-10-2016 05:43 AM
From Rob's sub-comment above:
"If you're trying to create an external class that uses the IWorkViewGetExternalClassDataScript interface, there's two methods of interest on that class. OnWorkViewGetExternalObject has the WorkViewGetExternalObjectEventArgs that exposes an ExternalObject that you can populate with attributes with SetAttributeValue. OnWorkViewPopulateExternalFilterResults.WorkViewPopulateExternalFilterResultsEventArgs provides access to the filter through FilterQuery; you can create several external objects through CreateExternalObject() and add them to Results."
If this isn't correct or you have anymore questions, comments, or need anything more in-depth, feel free to reach out to your first line of support, and if available, us at apisupport@onbase.com.
01-29-2016 12:23 PM
02-01-2016 05:12 AM
02-02-2016 01:17 PM
02-04-2016 06:31 AM
