11-01-2011 01:59 PM
Trying to get a viewer control integrated into an existing vb.net 3.5 framework application, through the hyland.services api. I can login, get a session ID, look up a documentID, and set all of the properties on the viewer control, but when I call CreateViewer I get this error:
[ERROR] Module: Viewer Library,
Class: COBImageViewerSvc,
Method: COBImageViewerSvc::Initialize,
Message: Error 0x80004005 occurred.
[ERROR] Module: ,
Class: ,
Method: ,
Message: A general error occurred.
Method: COBImageViewerSvc::loadImageServices,
[ERROR] Module: ,
Class: ,
Method: ,
[ERROR] Module: Presentation Library,
Class: COBLocalPageProvider,
Method: OBLoadImageServices,
Message: Failed to load image library [(null)]
[ERROR] Module: ,
Class: ,
Method: OBLoadLibrary,
Message: Failed to load current module handle [dmimage_alt] GetLastError [126]
I've tried the same code on an XP box, where I am a local admin, as well as a Windows 7 with a normal, non-admin account but with Visual Studio running as administrator.
Another developer, doing the exact same thing, on his computer, it works.
09-25-2013 06:37 AM
Issue is being marked as resolved. Although there was not solutuion posted for this issue it is assumed that it was a problem with the configuration since the this did work on another system.
For further inquiries regarding this type of issue please re-post the issue.
