11-21-2016 06:30 AM
We have some legacy VBScripts which were written using Hyland's Web services tool kit. Can someone point me to the right direction here?
The script does a lot of other things but this is where I am stuck.
The VB Script has a document and a snippet byte[] array. It takes the snipept byte[] array and makes it the first page for the document.
I have done with using Unity API. But using the new API's does Hyland still allow adding a page from VB Script?
Code Removed by Community Admin
11-22-2016 06:33 AM
Hi Smitha,
You might want to look at utilizing OnBase Client API from VBScripts. It allows you to add pages to a document using the method mzUpdateArchival. You can find more information in SDK.
11-22-2016 06:33 AM
Hi Smitha,
