12-10-2014 08:56 AM
I wrote a VB script that is executed by the user at indexing documents using the Index Ad-hoc Hook.
This is how the VB script
Sub Main35()
Dim obapp
Set obapp = CreateObject("onbase.application")
Dim keypanel
Set keypanel = obapp.IndexKeywordPanel
Dim keywordsCol
Set keywordsCol = keypanel.Keywords
Dim keyCount
keyCount = keywordsCol.Count
Dim objKeyword
Dim invDate
Dim dueDate
For i = 0 To keyCount - 1
Set objKeyword = keywordsCol.Item(i)
Select Case objKeyword.Name
Case "Date"
invDate=objKeyword.value
Case "Vendor Terms"
Select Case objKeyword.value
Case "20 OF MONTH"
dueDate=DateAdd("m",1,invDate) 'add 1 month to inv date
dueDate=Right("0" & DatePart("m",dueDate), 2) & "/20/" & DatePart("yyyy",dueDate) 'set the day to 20th
Case "10 OF MONTH"
dueDate=Right("0" & DatePart("m",dueDate), 2) & "/10/" & DatePart("yyyy",dueDate) 'set the day to 20th
Case "NET 23 DAYS"
dueDate=DateAdd("d",23,invDate) 'add 23 days to inv date
Case "NET 15"
dueDate=DateAdd("d",15,invDate) 'add 15 days to inv date
Case "NET10"
dueDate=DateAdd("d",10,invDate) 'add 10 days to inv date
Case "NET 30"
dueDate=DateAdd("d",30,invDate) 'add 30 days to inv date
Case "NET 20 DAYS"
dueDate=DateAdd("d",20,invDate) 'add 20 days to inv date
Case "NET20"
Case "25 TH OF MONTH"
dueDate=Right("0" & DatePart("m",dueDate), 2) & "/25/" & DatePart("yyyy",dueDate) 'set the day to 20th
Case "NET 60"
dueDate=DateAdd("d",60,invDate) 'add 60 days to inv date
Case Else
dueDate=invDate
End Select
Call keywordsCol.AddKeyword("Due Date",dueDate)'add the KW
Call keypanel.UpdateKeywordsEx(False,False)
Exit For
End Select
Next
Set keywords = Nothing
Set keypanel = Nothing
Set obapp = Nothing
End Sub
Problem is, that after the user clicks the ad-hoc button to run this script two KWs (both are currency) are getting deleted from the Index panel. user needs to re-enter them. Neither of these KWs are being modified in the script at all. The script looks at Date and determines a Due date based on KW vendor terms.
any thoughts?
12-12-2014 10:24 AM
This is a known issue in the IndexKeywordPanel in VBScripts. An SCR was created, but it was rejected. If you need this to be fixed, please contact your first line of support to have them request that the SCR be reconsidered.
This functionality does currently exist in the Unity API in OnBase 14.
12-16-2014 05:01 PM
Answer accepted,
any work around? does this still apply if the script hook is executed at post index>?
12-17-2014 05:04 AM
Larry,
1. The only workaround would be to get the document object and the keywords within the Ad-Hoc task prior to making any changes. Then, the last thing in your script should be to re-add the currency keywords to the keyword panel.
2. This issue does occur post index as well.
Have a safe and happy holiday season!
