02-27-2023 04:20 AM
You can tell me some step-by-step guide to access via Rest Api to Onbase using validated users from OKTA?
David.
02-27-2023 04:47 AM
The REST API does not handle Authentication. You will need to look into the Hyland IdP server. Searching the Hyland Community should provide a number of results but if you do not find your answer there you may want to consider contacting your first line technical support for further assistance.
02-28-2023 05:21 AM
Hi
If Daniel and Adam answered your question, please press the "ACCEPT ANSWER" button under Suggested Answer. This will reassure other community members that they can rely on this answer in case they have the same question.
Cheers!
~Alan
02-28-2023 06:21 AM
Ok, you have reason, thanks, Alan!
