11-29-2022 07:47 AM
We are planning to upgrade our OnBase from EP1 to 22.x. I like to know what authentication options are available for Plan Review Portal. Currently, the Portal is using SQL authentication in our EP1. Will we be able to using OKTA or Cisco DUO after upgrade? If so, do Plan Review portal users need to re-register their accounts?
Any information will be very much appreciated. Thanks in advance!
Margaret
12-01-2022 09:47 AM
Margaret,
Presently I have no knowledge of additional authentication options for the Plan Review Portal that would be available. Upon upgrading all existing portal accounts will work the same as before the upgrade.
However, the reviewer users using the Unity Client have other authentication methods available using IdP.
-Matt
12-01-2022 06:57 AM
Hi
I am reaching out to our Electronic Plan Review team to provide some advice to answer your questions. We will get back to you as soon as we have information or subsequent questions.
~Alan
12-01-2022 09:47 AM
Margaret,
-Matt
12-01-2022 10:53 AM
One thing of note: there is a way to manage the Plan Review Portal users using the "Plan Review Toolkit". This would not change the authorization process but would allow for an integration to another user management system.
-Matt
12-05-2022 06:59 AM
Thank you
