11-18-2022 07:06 AM
I'm wondering if various control properties on a unity form can be set via a CustomActionEventScript? Specifically, I'm wondering if the autofill property of a text box control (in a table) can be modified? My business case involves a text box control that has an autofill set. A custom action kicks off a script. In the script, I'd like to set the autofill on this particular text box control to none, do some work and then set autofill back to the afks it was configured with. Might this be possible?
11-22-2022 12:07 PM
Hi
Because this property is configured at the Unity Form Template level the API does not have the ability to toggle this on and off. Unity Forms Administration can only be done from the Unity Client Designer and cannot be modified programmatically.
11-22-2022 07:00 AM
Hi
I am reaching out to our OnBase APIs team for advice for your question. We will get back to you as soon as we have information or subsequent questions.
~Alan
11-22-2022 12:07 PM
Hi
