01-06-2017 07:42 AM
I'm currently working in Onbase 14 and I'm trying to use a Unity Script Hook instead of a VBScript hook and Hook into the Scan Queue - Post-Index event on the classic thick client. I've implemented the IScanQueuePostIndexEventScript interface in my unity script and configured the Script Hook to operate under the correct Context in Onbase Configuration but the script does not appear to execute. Should this work?
The wanted outcome should be the Unity script will execute once the user clicks on the Index button after indexing the document in the corresponding Scan Queue. Do I need to continue using a VBScript hook?
Please advise
01-06-2017 07:55 AM
Hi Roland,
All of the scanning and indexing Unity Scripts only run in the Unity Client. If you want a post index script to run in the Thick Client, you'll have to use a VBScript.
03-28-2018 05:37 AM
Hello Silvana
For Barcode scripts you add them in OnBase Configuration| Import| Barcode Process| Document Fields. Within Document Fields you have a drop down box where you can add your keywords you want to map to a barcode. Within that dropdown you will see your script.
03-28-2018 05:37 AM
Hello Silvana
03-28-2018 07:11 AM
