Thin client Thick client differences
Not applicable
I have an eForm that has a few check boxes on it.
<input id="Checkbox6" name="Checkbox6" type="checkbox" />
The form will display checks in the box when retrieved from the thick client.
The thin client will not display any of the check marks.
I need to know what has to be done to has the check box display the check mark on document retrieval on the thin client.
7 REPLIES 7
John_Anderson4
Star Collaborator
Star Collaborator
I've had nothing but issues trying to use checkboxes on e-forms, no matter which client I'm using. If at all possible I would recommend using radio buttons. It is possible to make checkboxes work, but it's more hassle than I think it's worth.
Not applicable
The check boxes show in the OnBase thick client. Fail to show in the thin client. The check boxes work, not the thin client.
John_Anderson4
Star Collaborator
Star Collaborator
Yes, I read your post. My recommendation still stands.
Not applicable
I am using the check boxes like below
[ ] Foot Soak
[ ] Oral Care
one option per item. If I used radio buttons I would have to double the clickable's for Yes and No. Creating clutter (noise), not a good usability design. The problem with radio buttons is the inability to deselect one. Is it really that difficult to get the OnBase thin client to see a checked box?
