05-16-2019 11:23 AM
New to OB. But learning fast..
Has anyone ever figured out a way to store a hyperlink into a keyword, then allow users to use that link.
We have web-based systems that will store their keys on some documents, I would love to find a way for users to launch those external websites while looking at the documents.
E.G. Keyword with value of "https://www.google.com/search?source=hp&q=OnBase" would be just like it is here and allow users to click it to launch the URL.
Thanks and sorry if this is a simple thing I am just missing in settings.
05-16-2019 11:48 AM
Daniel,
Are looking at wanting to enable "hot spots" on your documents similar to Cross Reference but with URLs?
If it's a keyword value you want to store as a URL, your users would have to retrieve the document then choose view the keywords.
Although I like the idea/question you posted, not positive this is possible. If it is, then cool I would use it.
05-16-2019 08:45 PM
Unfortunately there is currently no way to create a clickable hyperlink in a keyword or Unity Form field but there are SCRs for it.
I personally have an SCR #315595 for the Keyword fields on a Unity Form:
Ability to create hyperlinks to systems that can’t be embedded in OnBase eg payment systems which require a once off generated link based on the details the user has input. Static is something like example.com.au but user needs to go to example.com.au/< Keyword 1>/<Further Static Value>/<Keyword 2> and instead of copying that link into a browser manually we believe OnBase should see the string http: or https: to change the value into a clickable link or if Mailto:example@example.com open the users default mail program
