04-01-2016 08:14 AM
Good Morning -
Recently I have upgraded my Test System from 13.2 to 15.2. One of the things I tested deal with a special VB Script I have running in the background. Basically, if a Keyword is of a certain value, I pop up a message stating that other keywords need to be filled and prevent the user from continuing. What I noticed though is that under the Reindex(Pre Archive) script hook, Onbase automatically reverts to the original keyword values. So if I reindex the document, make some changes to the keywords and forget something, the script will kick in and revert back to the original values of the document instead of keeping the current values.
Keep in mind that this script works completely fine in 13.2, and when i try to reindex something and I get the message that i need something, the new values are retained.
So my question is this: has anything changed in this area from 13 to 15? If so, is there a way around it? Anything you can provide would be greatly appreciated. Thank you.
04-05-2016 11:40 AM
Hello again Chris,
That is indeed the code that should be used to cancel the Reindex process.
After talking to a few other employees it appears that the behavior you're seeing was introduced in SCR #155400, an SCR that was made to resolve a separate bugfix. A byproduct of that fix appears to be that the Reindex panel is being reset when the process is canceled. Currently we're investigating this issue and we'll most likely be creating an SCR to address it. I'll try to update this post to update you if an SCR is created to address this issue or if other action is taken.
Thanks Chris, sorry I don't have a good workaround for you
Update: Okay Chris, SCR #247613 has been created to address this issue. If you'd like to follow this SCR you can contact technical support to get yourself attached to the SCR.
04-01-2016 09:10 AM
04-01-2016 10:07 AM
04-04-2016 08:55 AM
04-05-2016 06:39 AM
