Platter State
Paul_Mefford
I am in need of deleting images, and the Onbase.id files from a copy2 of a volume.  I was going to manually remove the images, and Onbase.id from the file server, or thru a script, and then mark copy2 of of the volume as 'Delete (Removed)' within Onbase Disk group configuration.
As long as copy1 of that volume is still online image retreival should work fine, but if copy1 was unavailble would the Onbase client still attempt to look for the Onbase.id in copy2 volume that was marked as 'Delete (Removed')? Or is the Onbase sytem smart enough to realize that volume is no longer present, and will not attempt to look for a Onbase.id file?
5 REPLIES 5
Paul_Mefford
Need to reclaim drive space at our backup location. No copy 3 for disk group in question.
