04-11-2017 05:23 PM
Hi all - in both the CoreDeploymentGuide1600 and AppServer1600 MRG's, the Application Pool Best Practices both state that in the General Section the "Enable 32-bit Applications" should be set to "True" (and the default for these is True - for the AppNet Application pool - the normal 32-bit AppServer).
However, there is also an AppServer64 Application pool installed with the 64-bit AppServer (called AppServer64), and here the setting for Enable 32-bit Applications is set to "False".
Is this correct, and just not in the MRG documentation?
Thanks!
Ken Piper
SFSU
04-18-2017 07:03 AM
Hi Ken,
Thanks for the post.
Yes, this is correct. With the 32-bit OnBase Application Server you will need to set the "Enable 32-bit Applications" to TRUE since you will be running a 32-bit application. For the 64-bit OnBase Application Server, you will need to set that setting to FALSE since the setting will not work with a 64-bit application.
Take care.
