03-25-2021 05:21 AM
I've seen good helpful hints for auto numbering in a repeater section on a unity form - but that only works if users manually add rows. I have a DIP import that brings in all fields. It then creates unity form which is a read only form. I cannot get it to correctly add the row number. I do not need a count or sum - just a row number added for each line. I even added a keyword called row in the multi instance keyword group. Any ideas? I can add it in workflow if it can't be done on the form too?
04-27-2021 12:50 AM
Hello Jennifer.
Did you ever find the solution for your "Need Help Adding Row Number to Unity Form with Repeater Section containing multi instance keyword group" issue?
I am having the same experience, and all other threads seem to be when using a live form, not a "dipped" form.
Mickey
