mzSetQueryKeyword and Binary Operator for CustomQuery
Carl_Vincent
Hi guys,
I need to run a Custom query behind ths scene with OnBase API.
I need to do an OR operation for the same KW into mzSetQueryKeyword If I call it 2 times it will be an OR or an AND ?
Like
myapp.mzSetQueryKeyword(qryHdl,"VendorID",1, MZ_EQUAL)
myapp.mzSetQueryKeyword(qryHdl,"VendorID",2, MZ_EQUAL)
It will find VendorID 1 AND 2 or 1 OR 2
Tyler_Sorber
Star Collaborator
Star Collaborator
Hi Carl
Unfortunately, there is not a way to perform OR Operators within the Thick Client API.  As a workaround, you can perform multiple DocumentQueries to emulate the OR Functionality.
6 REPLIES 6
Sorry for the confusion.
Unfortunately, for OR functionality with this Query, the Unity API will need to be utilized. Essentially, an IWorkflowScript can be used in the Core Workflow Context for the business process.
Carl_Vincent
If I do that with Unity API and I want to show them, did I need a Unity Server Licence ?
Using : unityClientAutomation.DisplayDocumentList(displayDocumentListProperties);
Or if I already installed Office Integration it will use the Unity Platform but not the Unity Client ?
