02-18-2014 03:56 PM
What is the "Keyword Updater," how can I obtain it, and where can I get information/details about it's use?
Thanks-
Deborah
02-18-2014 11:26 PM
Good day Deborah!
Licensing - In order to use the Keyword Update, your system must have a Keyword Update license, in addition to a valid OnBase Client license. There is no cost associated with the Keyword Update license. To obtain a license for the Keyword Update module, you must submit a business case to Technical Support indicating how and why you intend to use Keyword Update. Keyword Update processes are very database intensive and can have a significant impact on your OnBase system.
Overview - The Keyword Update module allows you to quickly update the Keyword Values in your OnBase database. There are two specific Keyword Update processes designed to meet your needs. The
Global Keyword Update process will execute on every Keyword Value in the system, while the Doc Type Keyword Update process will execute only on Keyword Values inside your selected Document Type(s). Before running either process, you must create an index file containing the Keyword Values that will be searched for, added, replaced, or deleted (this file is similar to an index file for DIP or AutoFill Keyset imports).
-KeywordUpdater1300
More info can be found here: https://www.hyland.com/community/onbase_product_communities/m/ob13mrg/13276.aspx
03-07-2014 08:49 AM
Hello Deborah
I also have some keyword update problems
and What is keyword updater is it extra module ?
03-07-2014 08:55 AM
Hello Justin ;
I have updated keyword from 6 to 8 digit
but it not updated I extend keyword with from 6 to 8 but not applied
still I can not search by 8 digit do you have any idea ?
Nasir
03-07-2014 09:01 AM
Nasir,
If it's the Thick Client that you're trying to search, it needs restarted after the change in Configuration is made. If it's a core-based client (Web, Unity), then you need to recycle the appropriate application pool on the app server (or recycle the cache in OnBase Config).
Keyword Updater is an extra module (a no-cost one), and it is used to update keywords themselves. Updating the length of Alpha numeric can be done in Config without Keyword Updater.
I hope this helps.
Nick McElheny | Trover Solutions, Inc.
Lead Systems Engineer - Document Imaging
