03-08-2018 09:13 AM
Our customer needs us to create an external AFKS to accomplish a lookup against an MS SQL database. But the database is not configured to allow SQL Authentication. So in order to use Windows Authentication I will need to create and reference an ODBC. In order for the AFKS to be executed on a Unity Form, would the ODBC only need to be configured on the application server? Would the app pool need to be running with impersonation, using a domain account that has access to the database? In order for the AFKS to be executed on a document by a workflow timer service, would the service need to be running with such a domain account?
Also - we need to do something very similar with a Unity script Connection String. The script gets run on a Unity form. The form will be used in the web client and Unity client. Can the connection string be set to use the ODBC that is configured for Windows Authentication? Does anyone have an example of a connection string for connecting to an MS SQL database using Windows Authentication? Would the ODBC need to be set up on both the application server and web server (for the web client usage)? And would this again be the app pool impersonation account that would be making the actual connection?
Any tips and/or examples that anyone has regarding accomplishing what we are trying to do, or something similar, would be greatly appreciated! Thanks!
03-08-2018 10:35 AM
Hi Brian,
The standard format for a SQL Server connection string using Windows authentication is this:
Server=myServerAddress;Database=myDataBase;Trusted_Connection=True;
You can find many examples, including those for more esoteric cases at https://www.connectionstrings.com
Hope that helps,
Scott
03-08-2018 10:35 AM
Hi Brian,
Hope that helps,
Scott
03-12-2018 03:11 PM
Thanks, Scott. That worked well for me.
