Docpop page numbers
Smitha_Challa
This might be a weird question.
Hopefully someone has some input or comments about it. I am not even sure if this is right way to do this
This is my code to invoke docpop
   UriBuilder uriBuilder = null;
uriBuilder = new UriBuilder("http://appserver/");
uriBuilder.Path += "docpop/docpop.aspx";
uriBuilder.Query = string.Format("sessionid={0}&docid={1}&listtype=html&viewertype=html", sessionId, _DocumentID);
Response.Redirect(uriBuilder.Uri.ToString(), false);
This is my code to invoke the url to docpop. It opens docpop in viewertype= html mode. Is there a way I can give this html string a page range starting page to ending page?
When do I choose opening docpop in html mode compared to activex. Would it be possible to give it a range if I open docpop in viewertype = acitvex
Thank you
Scott_Johnson3
World-Class Innovator
Hi Smitha
There is a pageID parameter that will open the document on a specific page.  Check out the docpop MRG for more details.
Good Luck
Scott
9 REPLIES 9
Smitha_Challa
Any suggestions?
Scott_McLean
Elite Collaborator
Elite Collaborator
There isn't any URL component for page range in a DocPop URL, so it would not matter whether you choose ActiveX or. HTML.
Smitha_Challa
So does that mean DocPop always shows starting from page 1 to ending page
Smitha_Challa
Ok thanks
