04-25-2013 08:04 AM
Hi
Before I discovered I could have renamed a doc type, I tried to delete one that I misspelled. I did rename it (yyy) but I would like to delete that one. I signed in as MANAGER but I didn't see a button or anywhere where I could delete the document.
04-25-2013 08:15 AM
You need to have athe -ROMANZO switch applied to client to see that option.
04-25-2013 08:31 AM
I thought I'd be doing this in CONFIG; I applied the -ROMANZO switch to the Client; I still don't see where I could delete a document type.
04-25-2013 08:33 AM
Robert,
I believe he was referring to OnBase Configuration. To clarify you will need to apply this switch to the Configuration shortcut to see the Delete button.
04-25-2013 09:46 AM
That did it...thanks!!!
