02-20-2024 10:08 AM
We want to move a few hundred documents from our production system to our test system. I assume that when we export the documents from our production instance to our test instance it will come with a DIP file to import the documents into test.
How do other users accomplish this task?
02-21-2024 09:05 AM
Hi
You can use the Export feature in OnBase Configuration to export the Document Types from one environment and import them into a different one.
Best wishes.
02-21-2024 10:05 AM
In the Thick Client, you can search for the documents you want to export. From the results list, select the desired documents, right-click and click on Export to DIP File. That will create self-configured DIP file. You place that in the production Disk group folder. In the test environment, set up the DIP process.
More details: https://support.hyland.com/r/OnBase/System-Administration-Cloud/Foundation-23.1/Cloud-System-Adminis...
I know this says cloud administration, but it works in on-prem environments as well.
