Copying documents from a production system to a test instance.
Rowlen__B_Wilso
We want to move a few hundred documents from our production system to our test system. I assume that when we export the documents from our production instance to our test instance it will come with a DIP file to import the documents into test.
How do other users accomplish this task?
AdamShaneHyland
Employee
Employee
Hi @Rowlen Wilson ,
You can use the Export feature in OnBase Configuration to export the Document Types from one environment and import them into a different one.
https://support.hyland.com/r/OnBase/System-Administration-On-Premises/English/Foundation-22.1/On-Pre...
Best wishes.
Kris_Conrads
Elite Collaborator
Elite Collaborator
In the Thick Client, you can search for the documents you want to export.  From the results list, select the desired documents, right-click and click on Export to DIP File.  That will create self-configured DIP file.  You place that in the production Disk group folder.  In the test environment, set up the DIP process.
More details:  https://support.hyland.com/r/OnBase/System-Administration-Cloud/Foundation-23.1/Cloud-System-Adminis...
I know this says cloud administration, but it works in on-prem environments as well.
