03-12-2019 12:32 PM
In the class for API certification we covered using OnBase Studio to produce client-side scripts. Our organization is solely using the thick client. Is it possible to build a client side script (such as IClientScript) with OnBase Studio and use it in the thick client?
03-13-2019 07:50 AM
Hello David, the OnBase thick client does not support Unity Scripts unless they are run within the context of the core user interface like workflow, or they run or are executed by the OnBase App Server like a Unity API DataSet or Autofill Script. Since the Thick client main interface does not use the core, Unity scripts cannot execute within the main interface like an IClientScript can within the Unity Client.
What can run within the thick client interface are VBScripts. I believe their may be material that cover this information but you will probably need to work with API Support for such content.
03-13-2019 07:50 AM
