06-13-2022 08:27 AM
How where clause should look like 'where dt.itemtypename= @{OTPDoctype}' if Allow multiple selection option is used. It gives me an error ' Incorrect syntax near the keyword 'NOT' when i select Allow dynamic logical operator. It give me an error '' Incorrect syntax near ',' If Allow Dynamic logical operator is not selected.
06-17-2022 08:51 AM
Hi
According to the following notes in the Reporting Dashboards - OnBase Foundation EP5 Module Reference Guide, you are only allowed to use IN or NOT IN operators.
Page 196
Note: If Allow dynamic logical operator and Allow multiple selection are both selected, the only logical operators available are IN and NOT IN, which allow the user to search for values within (when using IN) or not within (when using NOT IN) the parameter.
Page 273
Note: Without Allow dynamic logical operator enabled, the Allow multiple selection option is only valid in an IN SQL clause.
I hope this helps!
~Alan
06-27-2022 09:24 AM
Hello Natalya!
If we answered your question, please press the "ACCEPT ANSWER" button under the helpful Suggest Answer. This will reassure other community members that they can rely on this solution in case they have the same situation. Otherwise, let us know so we will continue to look into this issue/question.
Thanks!
~Drina
