06-26-2023 11:15 AM
We have been testing Integrated Office Viewer for several months, but we just encountered a big issue with our largest business unit. They have several files stored as XLS format instead of the more modern XLSX format, and this is causing issues since the XLS file is read-only. Before WOPI was enabled in our lower environments, the users could open the Excel document in Unity and edit directly within the client before using SEND TO to save to a pickup folder for preprocessing job to split the Excel file. After WOPI, user is forced to view XLS file in read-only mode. This would require the users to save the file externally, modify it, and resave to a pickup location with a specific naming convention OnBase already does with the SEND TO. This would cause extra clicks for the user group, and that would not be acceptable in trying to streamline things.
. We were considering writing a Unity Script that can be called via Web Service which takes the XLS file and creates a rendition of the current document already stored in OnBase.
This is the first time I encountered a use case like this, so trying to find the easiest yet most durable/efficient approach here.
08-07-2023 12:12 PM
We've been changing the excel options|general to Optimize for compatibility. What happens when you do this?
Our issue seems close, but different, so it still may not work for you... Note: even if it does work if you have 1000 users using excel, that's a lot of manual changes.
Regards
