06-21-2013 05:41 PM
Hi All
In 12.0.3.217 the Unity Automation IDE intellisense does not work for some core objects such as strings. The stuff that does not work is the .Net core dll. For example, you cannot simply add a using System.Strings statement. It is not in the GAC objects available for referencing and when I try to add it to the GAC I get a duplicate object error message. However, if I type the methods manually the script builds find and it runs as expected. (I did try adding System.core but that did not help). BTW in visual studio the intellisense on string methods work out of the box without any extra references.
Any suggestion?
09-19-2013 08:15 AM
Scott -
There have been some problems with intellisense disappearing in the past. Typically if you close the editor an reopen, your intellisense would return.
In OnBase 13, the intellisense feature was overhauled and is available consistently.
Thank you,
Alicia
