08-03-2021 01:34 PM
I have written an iClient script that should be visible in the tasks tab of the Unity client. Some users are reporting that the tasks tab is not visible and some are reporting that the "Execute Task for script tasks" is not available. What are the permissions necessary to get these users access to the scripts? I don't see anywhere to assign it to a doctype either (like the system tasks). I know it's probably one of the multitude of check boxes but which one(s)?
08-17-2021 12:01 PM
Update
In case anyone else is curious do the following:
In users and groups
- open the appropriate group
- go to product rights and add run scripts right under administrative privileges
In studio
- open Manage Unity Projects
- select the script
- Click Update Client Info
- Add the group under "What permissions do you want the Unity Script to have?"
Reset and relog
In my opinion that is a really poorly named security groups box.
08-17-2021 12:01 PM
Update
In users and groups
In studio
- select the script
Reset and relog
