08-21-2013 07:00 AM
I have a potential customer who would like to know if unicode is supported?
They are an English based company and have documents they would like to store in the system that have come from China for example and they would like to do a copy and paste of of the Chinese company name and index a keyword called company name using this character set.
I have done a quick test on the V13 9seconds food demo and i can import a document and index keyword a field using the following characters (Japanese in this case)
I can retrieve the document using the keyword value of
However the autoname strings displays all ????????.
Is there a way I can get OnBase using the unity client to display the characters as expected?
Many thanks
Paul
08-21-2013 07:25 AM
Hi Paul,
Thank you using Community.
OnBase is built on top of Microsoft .NET which natively supports Unicode. Our storage of content such as documents supports Unicode but the database does not currently support Unicode. The support of Unicode is targeted for a future release.
In the scenario that you have provided, the reason you are able to store keywords in Japanese is because your database collation is set to Japanese. But how did you accomplish this? Did you simply change the collation to the 9SF demo database to Japanese or did you import the 9SF demo database into a newly created Japanese database? The reason I ask this is because when changing the collation on a database that has been created with a Latin collation, all newly created tables will be using the Japanese collation (new keywords for example), but all old tables created prior to the collation change will still be using the Latin collation. In this case, the autoname table is created at the time of the database creation therefore still using the Latin collation.
My suggestion is to try to export the 9SF database and import it into a new Japanese database and this should solve your issue.
Please let me know if you have any additional questions.
Thank you,
Alexandra Coman
International Solution Analyst
Hyland Software
08-21-2013 07:32 AM
ALEXANDRA, you say that "OnBase is built on top of Microsoft NET which natively supports Unicode". Is this true for both the Web/Unity clients as well as the Thick Client, and all the processing options available in via the Thick Client (i.e. DIP, COLD, Autofills, etc.)? Can we use Unicode index files for these processes?
08-21-2013 08:03 AM
Michael,
I apologize. I should have made myself more clear. This is true for the Web Client and Unity Client but not for the Thick Client. We currently cannot process index files that use Unicode as an encoding via DIP, COLD etc.
Thank you,
Alexandra
08-21-2013 08:20 AM
Hi Alexandra,
Many thanks for the reply.
I made no changes to the OnBase database. The 9 second foods has been left as provided.
This is what the Unity client looks like when I retrieve the document using the characters that were entered to index the keyword company name.
I want to be able to store keyword values in English ,Chinese ,Japanese e.t.c and the autoname string to return the value that has been entered.
I get the impression this is not possible? Due to the database collation having to be one or the other?
