04-07-2015 10:52 AM
I'm looking to set up a new set of doc types in our system. We use all caps keywords, but I like the look of mixed case better. Are there any cons to using mixed case when setting up the keyword types?
Thanks!
04-08-2015 01:16 PM
I would agree. It's best for longer "descriptive" keywords. For shorter keywords that are just metadata, uppercase is still probably best. Also, anything that needs to be rendered visually as mixed case (like an address) is a good candidate for mixed case.
04-08-2015 01:46 PM
Thanks Nat, Marcus, Jose and John! I appreciate your insight.
Danielle
04-21-2015 02:46 PM
04-22-2015 07:25 AM
Thanks Nate! I remember we did this in Sys Admin training and made a sentence out of AP invoices or something like that. Doesn't fit this scenario of mine, but I appreciate it!
06-17-2015 01:15 PM
We had an issue using mixed case for indexing as user was able to index with mixed case and it did not match case in the keyword dataset. Also doc retrieval also does not recognize mixed case for searching. Please remember that if the keywords are to be used in workflow rules, then this is where the case becomes critical.
