04-08-2014 06:13 AM
I have 65,000+ documents that USED to have a mikg....I changed them to be single instance and re-did the auto name string. Now the kw's are gone. I can see them in the document history (added but nothing deleted)
My question is this:
what is the best way to access the information that I need? the kw's value that I need to reindex the docs.
Darcy West
04-08-2014 06:19 AM
How did you change the MIKG to single instance?
04-08-2014 06:45 AM
First I removed the mikg. Then I added the single instances back in. (the kw's that were added back in are in the mikg)
04-08-2014 06:56 AM
The data would still be in the database table for the MIKG. If you want the data transferred to standalone keywords or a single instance keyword group, you'd most likely need to work with your first line of support.
04-08-2014 10:16 AM
My first line of support contacted me about this....He assured me that my data wasn't 'lost'. I could go back to the MIKG and the data would still be there. However, currently there is no way of going from MIKG to single instance.
