Is it possible to Delete a User Group?
Greg_Charles
We have several now that are no longer being used. Would be nice to clean that mess up and only have available the options that we need.
Justin_Fandl
Employee
Employee
Hey Greg,
I believe you will need to log into Configuration with the -ROMANZO switch applied to the shortcut to be able to delete a user group. I verified this does work in Version 13.0 with the switch applied and logged in as Manager.
Hope this helps!
7 REPLIES 7
Jared_Jozsa
In v14, assuming the account you are logged into has approriate rights, navigate to configuation:
Users > User Groups & Rights
Ah Ha! we are still on V13, but we have a pending upgrade to 15. So I guess I will revisit this then. Thank you!
Jared_Jozsa
Do you have access to configuration? You can delete user groups in v13, but it has to be done from configuration.
Greg_Charles
I do have access to Configuration, however there is no Delete button next to Create. I have full administrative privileges. I even logged in as the Manager account just to make sure.
