Help with updating a workview object in an ISchedulableScript.
Keith_Malek
I'm trying to figure out the code to update a workflow attribute from a workflow script.
I've been trying variations of the following with no luck;
						Hyland.Unity.WorkView.WorkView wvModule = object;						Hyland.Unity.WorkView.Application wvModule = wvModule.Applications.Find("WorkFlowMonitor");												wvModule oWorkFlowMonitor = Hyland.Unity.WorkView.WorkViewObject;						AttributeValueModifier avMod = oWorkFlowMonitor.CreateAttributeValueModifier();						avMod.SetAttributeValue("LastRan", currentTime);  					    avMod.ApplyChanges();
Any help would be greatly apresheated.
Keith
Keith_Malek
I figured it out as:
Hyland.Unity.WorkView.Object wvObject = wvClass.GetObjectByID(objectID);Hyland.Unity.WorkView.AttributeValueModifier attrValueModifier = wvObject.CreateAttributeValueModifier();attrValueModifier.SetAttributeValue("LastRan", currentTime);attrValueModifier.ApplyChanges();
Keith_Malek
