04-20-2020 09:25 AM
I am redesigning my duplicate invoice logic and running into a few road blocks. My first try, I created a unity LC using portfolio relationships for each keyword value like PO #, Invoice #, Vendor Name and Invoice Date. I did Invoice to invoice. I also did rules for each and on true would ask about the next value. During testing I found that it wasnt looking at the same document for these values but if these values existed on any document in onbase. I decided to try mapping all my values on 1 relationship but this doesnt work either. It keeps going false even though there is a doc with PO # and Invoice #. I need to be guided the right direction as I dont know what the common way to perform this. Our old setup uses folder types using invoice or PO# and this doesnt work hardly at all. Any advice would be appreciated.
04-20-2020 10:27 AM
You want to exclude primary, because you don't want it to ever match itself.
Invoice is tough: it would be interesting to see others opinion.
PO, Invoice and Vendor # is probably the safest way to go. Vendors may change names, and they may re-issue invoices with a credit or different invoice amount (net terms, etc). I have seen scenarios in which vendors may tag an 'a' or another value at the end of the invoice for the re-created invoice.
We had scenarios in which the invoice would come through the dropbox and the buyer spoke directly to the vendor and they emailed them the revised invoice.
I had always erred on the side of more human scrutiny just because of how unpredictable the vendors have been.
04-20-2020 10:39 AM
why not invoice amount? This seems to be a good indication of if this is a duplicate?
04-20-2020 10:45 AM
True. I guess it depend on what you are matching. I guess it would be based on what scenarios you see. I have seen enough occasions in which a vendor sends and invoice but forgets a discount or a contract cost. They will modify that invoice and re-issue. The invoice # and everything will be the same but the amount will differ.
04-20-2020 10:59 AM
great info and thank you sir
