11-20-2014 05:25 AM
I have a customer that is looking for a way to run a Custom Query and display the number of pages for each of the documents. Is there any way to do this. Custom SQL query?
11-20-2014 09:16 AM
Seth, I am using your script you created everything is set up in Unity API and was able to save an published successfully Added my keyword of page count to the documents. Created a System WF to run action (run unity Script) Choose my new script. I am getting an error in Diagnostic console
Document lock not Obtained "source line 59 - GetAndStorePageCount.GetandStorepageCount - OnworkflowExecute
line 49 ' Lock document: using statement handles disposal of DocumentLock object and releases lock
line 51 ' Alternatively, DocumentLock.Release may be called to release the lock
Line 53 Using documentLock As DocumentLock = document.LockDocument()
Line 55 ' Ensure lock was obtained
Line 57 If (documentLock.Status <> DocumentLockStatus.LockObtained)Then
Line 59 Throw New Exception("Document lock not obtained")
11-20-2014 11:00 AM
Todd,
My initial thought is that if you already have a document lock on the document via the viewer and then the script tries to establish a new lock, it would fail (like opening the same document in two different viewers in any of the clients) even though it's the same user.
Can you create a lifecycle and then a WF Timer that runs the Unity script?
Take a look at this screen print:
I don't mind making your life easier by sending you an export of my LC. You'd need to apply your document type to the LC though, or create a System Task to add the selected docs to the new LC.
Cheers,
Seth
11-21-2014 08:07 AM
Todd,
You also might be able to remark out the lock process from the script and have it work... That might not work, though...
11-21-2014 08:17 AM
Seth: thanks for the script. I have a feeling that's going to come in handy. Couldn't he just add code to clear any existing locks before he tries to obtain a new one? Assuming of course, this is not permissions issue with with the account running the action on the disk group...
11-21-2014 08:51 AM
[quote user="Jose Pineda"] Couldn't he just add code to clear any existing locks before he tries to obtain a new one?
Possibly. The way that he's running the script (System Task, as I understand it) should take into account his own personal lock on the document, so perhaps it's something else.
Since he's able to retrieve the document in the Unity Client, I have to presume that the APP Server has the correct permissions to the Disk Group.
