05-05-2016 01:42 PM
I found in the documentation in Appendix A regarding the the Status field of the ArchivedQueue. Is there a table in the database that contains a cross reference from the number to the textual queue value? I tried looking in the documentation and the database and could not find anything....
05-06-2016 10:53 AM
Hi Peter,
If you're going to be maintaining your own table, it's probably more prudent to create another database where you can maintain this table, and synch the data during off-peak times. This will minimize the chances that your data object(s) could adversely impact the OnBase database.
Just a suggestion.
Mike
05-06-2016 07:53 AM
Hi Peter,
The translation of the status values is not stored in the database. You'd need to consult the Database Reporting Guide to translate the values.
Ansley
05-06-2016 08:16 AM
05-11-2016 01:13 PM
06-22-2016 10:41 AM
I understand that changing the strategy now is difficult. Moving the codes and their values into the database could be a pain for OnBase developers as all those codes will need to look into the database versus wherever it is hardcoded or being fetched from now. But I don't understand why the keeping the values in database would result in less integrity or any change in the value would need changes in multiple locations. As matter of fact, I think it other way. The values in DB would have worked as common vault for this data. I am dealing with so many systems and databases at my location (I am a DBA), and every system keeps this kind of data in database. Many times, I had also come across with the situations where management would like to have some analytical info from OnBase data, and I always missed this piece of data. As matter of fact I was shocked to find out that this is not in database, when first such analytical request was made to me by management. Just a suggestion: May be OnBase will come up with some robust reporting module, so that the DBAs or the systems admins do not need to run any queries/reports. Don't take my comment wrong way please. But I agreed with the original request and had same frustrations sometimes.
