02-05-2021 12:20 AM
I just want to verify if the OnBase can connect via a non standard port in sql. Thanks in advance
02-05-2021 08:25 AM
Hi Val.
This shouldn't be a problem if you are using a non-default port for your database. Here is an article which discusses how to configure the connection string for Microsoft SQL Server using the System.Data.SqlClient connection string. More specifically, the Data Source value is where the port is configured.
Here is another link which might be helpful.
https://www.connectionstrings.com/microsoft-data-sqlclient/
Best wishes.
02-05-2021 08:25 AM
Hi Val.
Best wishes.
