02-27-2024 09:01 AM
Is the AWS S3 Multi Region Access Point Supported for OnBase S3 Disk Groups?
03-05-2024 06:56 AM
Hi
At this time (as of OnBase 24.1), OnBase does not support AWS S3 Multi Region Access Point for S3 Disk Groups. R&D is aware of the request for the functionality.
Best wishes.
02-28-2024 08:08 AM
Hi Adam,
I will need to check if we specifically tested against multi-region access points, but in the meantime have you tried unchecking the Override Region box? From my knowledge of MRAPs, they cannot use a specific region in the request.
Mike
02-29-2024 04:49 AM
Enabling the Override Region was a requirement for sts to work.
https://docs.aws.amazon.com/AmazonS3/latest/userguide/MultiRegionAccessPointRestrictions.html
03-04-2024 09:36 AM
We will have to wait on an answer from R&D on how the request to S3 is being generated and formatted to see if it's compatible. I see a couple limitations from AWS that may prevent our implementation from working correctly.
03-05-2024 06:56 AM
Hi
Best wishes.
